All actifsource 'preferences.properties' which are under '.metadata\.plugins\org.eclipse.core.runtime\.settings' can now also be defined externally via system properties.
With this setting, these values are automatically used as default values.
This can be done directly in the 'eclipse\configuration\config.ini' folder, or it can be defined directly under maven in a product definition, for example:
