Eclipse supports two different color theme profiles, Light and Dark by default. This can be set via 'Window->Preferences->Appearance'.
Actifsource also supports different theme profiles which can be set via 'Window->Preferences->Actifsource->Appearance->StyleConfiguration'.
To make the setting easier for the user, the Actifsource Profile should also be switched implicitly (Dark or Light) when the Eclipse profile is switched (Dark or Light). This is done as long as no one has manually selected a specific actifsource profile (Resetting is done via the 'Restore Default' button).
