Release: Actifsource V11.3.0
It should be possible in all selectors or codesnippets to delete only the desired character via 'Backspace' or 'Delete' instead of the whole token:
Example1:
Change the property from 'this_is_a_property1' to this_is_a_property2.
Set the curser to the end from the selector:
and press 'Backspace':
Select property 'this_is_a_property2':
!!! The same behavior can be achieved as before via Ctrl+Backspace or Ctrl+Delete. !!!
Example2:
Set the cursor inside the property:
and press 'Delete':
Example1:
Example2:
and press 'Delete':
