TemplateFunction
Support questions relating to the actifsource Template Editor
TemplateFunction
Postby meierd » Fri Jan 18, 2013 9:35 am
Hi,
What is the purposes of attribute filetype in a TemplateFunction (and why it get's not automatically set until I extracting the subtemplate form the parent template)?
meierd
Re: TemplateFunction
Postby reto » Fri Jan 18, 2013 9:41 am
The file type in the template function has the same purpose as the file ending in the template editor. It chooses a syntax style model to highlight language keywords and comments.
If your template function generates java code, use java als filetype. If you plan to write C++ code, use hpp or cpp as file type.
* See also http://www.actifsource.com/tutorials/co ... style.html
There are discussions to refactor this part of the model.
reto
Return to Template Editor
